On the play list when right clicked it gives you the option to mix now, is there anyway i can make it a shortcut so to mix the next song in the playlist because sometimes i want to cut a song short but dont have the time to right click mix now etc
so was wondering if there is a mix now shortcut or alternative way around this
geposted Thu 06 Oct 11 @ 5:14 pm
here you go
mix_now : Smoothly crossfade from one side to the other, using beatsync if both songs have enough beat.
mix_now_nosync : Smoothly crossfade from one side to the other.
mix_next : if the non-playing deck has a song loaded that's already been played, load a new one from the playlist. then, smoothly crossfade from the playing deck to the other, using beatsync if both songs have enough beat.
mix_next_sidelist : if the non-playing deck has a song loaded that's already been played, load a new one from the sidelist. then, smoothly crossfade from the playing deck to the other, using beatsync if both songs have enough beat.
geposted Thu 06 Oct 11 @ 6:05 pm
Is there a computer keystroke short cut to mix into the next song in automix?
geposted Sun 13 Oct 13 @ 4:20 pm
automix_skip
geposted Sun 13 Oct 13 @ 6:23 pm
