It has happened a few times, every time is a little different.
Step 1 - I select all the songs for a set I want to record by putting them on the playlist sidebar
Step 2 - I save such list as a playlist
Step 3 - I start mixing going down the list
Step 4, sometimes I look through the files to see if there is another song I want to mix in, and as I click around the folders or the search, the list from the right all of it just clears up.
WTF?
Can this be fixed?
As you can see I have the VDJ pro 7.0.5 Mac
MacBookPro13
Feel free to move this thread to where it better fits, however, I seem to never get answers in other forums.
Thanx to all. :)
WTF?
Can this be fixed?
MacBookPro13
Thanx to all. :)
geposted Fri 07 Oct 11 @ 10:03 am
Set your Auto Load Playlist option in the Config->Options tab to Disabled.
geposted Fri 07 Oct 11 @ 10:35 am
Thanx! Rapid response here, seems like in the Mac forum things go unnoticed for weeks.
Oh well, either way thanx. Problem solved.
geposted Fri 07 Oct 11 @ 11:43 am
my right side playlist dissppears when i load it and try and play....any ideas
geposted Sun 12 Jan 14 @ 11:13 am
Please do not post the same message more than once.
forum rules
forum rules
geposted Sun 12 Jan 14 @ 11:16 am
