I just bought a new dbx driverack PX and eagerly picked it up from a Long and McQuade store last Friday. I'm using the driverack PX to compliment my mackie srm 450v2 and mackie hd1501. I tried to set it up in my basement but getting trouble balancing the speakers and the pink noise generated during this process is really loud! Maybe it's just not possible to set it up in a narrow location. My basement is about 11' x 20'. I'm also baffled with the AFS setup as no further detailed info as to what would be the normal no. of fixed and live filters. I do understand the compressor part because I also have a dbx 166xl compressor. Can someone using the product provide tips on setting up a driverack PX?
geposted Sun 09 Oct 11 @ 12:20 am
I wouldn't set up that way, otherwise you are going to have to do it at every venue. All you really edd to do is set up the frequencys for your speakers both tops and subs.
geposted Sun 09 Oct 11 @ 9:20 am
Thanks for the answer!
geposted Sun 09 Oct 11 @ 3:57 pm
