Good Evening all,
So here is what I got: Dell XPS m1530 running windows 7 and VDJ Pro Full new 7.5 version.
The Problem:
I added a new virtual folder Example:Line Dance; then I dragged a few songs into the folder. I click on the new folder line dance and the songs are there and play. Once I close out of VDJ and come back in (does not matter if its right away or 2 days from now) the folder and its contents disappear. If i create a virtual folder and do not put anything in it, when I reopen vdj the folder is there.
I have never had this issue before and I have ran out of ideas. I have changed where vdj is stored, uninstalled and re-installed and nothing seems to work.
Thank you in advance for all your help in this matter.
The Problem:
geposted Sun 09 Oct 11 @ 7:27 pm
Virtual folders are stored in the VirtualDJ database. If they are lost when you close the software then this means that VirtualDJ doesn't have permission to write to its database to save the changes.
Please see https://virtualdj.com/wiki/VirtualDJ%20Folder%20Permissions.html
geposted Mon 10 Oct 11 @ 4:45 am
