Does anybody now if it's possible to have VDJ show special color icons for songs that are good candidates for harmonic mixing, just like the color icons for BPM match +/-20% and color icons for songs already played this session
Since the key detection is already there, and the music theory behind it is fairly simple (like using the Camelot wheel), it feels like the option would probably already be in VDJ somewhere, but I can't find it
Any suggestions (beside using the Camelot wheel or another tool manually, of course)
I'm problably lazy but I kind of like the little color icon hints (especially the red ones are great at my age where I can't remember further back than the last few songs :-)
Best regards
/Klaus
Best regards
/Klaus
geposted Mon 10 Oct 11 @ 8:50 am
There is no icon for this, but there is a filter folder named Compatible Songs which shows the songs that are within key and BPM range.
geposted Mon 10 Oct 11 @ 10:37 am
there is also a field on the browser called "key diff" that has the numeric value of how far a track is from being compatible. someone from atomix might need to confirm but i think it works like
keydiff
0 - perfect mix - complimentary key up and down, same key
1 - energy boost/drop - one semitone higher/lower
2 - forget about it, will clash
keydiff
geposted Mon 10 Oct 11 @ 10:53 am
It works :-)
Thank you!
Best regards
/Klaus
Thank you!
Best regards
/Klaus
geposted Mon 10 Oct 11 @ 11:01 am
keydiff
keydiff
And that also works fine
Thanks to both of you. I can't beleive I didn't find it myself
/Klaus
geposted Mon 10 Oct 11 @ 11:06 am
When I use harmonic mixing I simply have the Camelot Key column visible and just sort by that column.
geposted Mon 10 Oct 11 @ 2:15 pm
