Hello all,
please I need your help for a friend.
He has got the MEP 7000 and he is not so familiar with computer skills so I will help him with this.
Can he use the MEP 7000 with VDJ ??? ...but he wants the cd ports to be used when neccessary..
What will be the setup if something like this is possible???
Thank you in advance for the help
Jim
Jim
geposted Wed 12 Oct 11 @ 6:13 am
No problem.
On the mep 7000 you choose which source you want to play - you choose cd or usb or pc.
you have to connect the mep 7000 with an A-B usb cable (same type like you connect a printer).
You have to download the mep 7000 drivers from the pioneer pro dj website and install them on your pc.
Then connect the mep 7000 to your pc and then run virtual dj.
You have to choose the right sound setup.
geposted Tue 20 Dec 11 @ 2:54 pm
