Hello,
My Equipment:
DJM600
CDJ900
I need to connect my DJM600 to my VDJ7 which is on windows XP PC. I do have soundcard with M-Audiodata Audiophile. How can I control my software with my mixer? My CDJs are connected directly through USB and work good, I just need mixer to be connected to the software, please help :)
My Equipment:
DJM600
CDJ900
geposted Wed 12 Oct 11 @ 11:47 am
You need to buy the software first, VDJ PRO FULL to do what you want to do.
Plus I don't think the DJM600 has MIDI the DJM700 has though, and the CDJ900's are natively supported with HID (no need for time code's) with VDJ PRO FULL. One last thing the CDJ900's also have sound card's built in.
geposted Wed 12 Oct 11 @ 12:46 pm
I am using VDJ PRO FULL, just not registered.
CDJs work ok, but sometimes there is a lag, and songs do not play as smoothly as played from CDs or FlashDrives.
But somehow I need my mixer to be connected, I read forums where people were able to connect, but never found instructions on how to do it... any help would be appreciated!
geposted Wed 12 Oct 11 @ 1:39 pm
What version of VDJ7 are you using and are you on pc or mac? You should register for all the free plugins and updates as well.
Like I said there is no MIDI on the DJM600, you can still use it just like a normal mixer with VDJ though. To set VDJ up with a normal mixer you should read the manuals that came with VDJ.
geposted Wed 12 Oct 11 @ 2:28 pm
What a surprise a NLU not replying when you try to help them and ask them to register their software!
geposted Thu 13 Oct 11 @ 5:01 pm
