I use an external drive for music library and see the VDJ search database is stored on that drive. When accessing from another pc (windows), the search db is in tact (excellent). I also found that the virtual folders transfer as well (very cool). However I want to be able to create a bank of Samplers and have that SAME bank of samplers also appear on the second PC (for backup purposes). Is there a config file for samplers (or VDJ in general) that can be copied (mirrored) on the 2nd pc (so I dont have to recreate every time). Did a search and couldn't find anything, I cant be the only one wanting to do this? Anyone know how?
geposted Wed 12 Oct 11 @ 10:57 pm
I use a Program called Jingle Pallete for my my samples, as it has facility for banks of samples, andas long as you have secondary monitor they are visible for you immediately, I use a touch screen for second monitor and find it awesome.. best thing is its free...
geposted Fri 14 Oct 11 @ 4:46 pm
make sure you have the samples in the same file location on both computers, downoad the sampler manager plugin then, load up all your banks on one computer then copy the configuration file over to the second computer. If you need to change the filepath between computers you can by opening the configuration file with notepad, and using "find and replace"
https://virtualdj.com/addons/1046/Sampler_Manager.html
geposted Fri 14 Oct 11 @ 6:36 pm
