Hey Guys just looking for some info, i'm a Macbook new-bee so dont know much about config problems, ok heres what i have
Model number: Macbook
Model identifier: Macbook 4.1
Processor Name: Intel core 2 Duo
Processors: 1
Total number od cores: 2
L2 Cache: 3MB
Memory: 1GB
Bus Speed: 800Mhz
Is this macbook good enough to run VDJ without any hick-ups, I'm hoping (YES), at the moment when running VDJ after bout 4 mins the music skips and then its fine then it skips, this happens on going. What is it that i need. Is it more Ram?? Is it more memory?? Or is it a macbook pro, if so is it possible to upgrade my macbook.
I Bought it of a guy from America i'm sure, or was he from Australia............ HeHe cause it keeps skipping.
I'm testing it on the internal sound card and it skips i also tested it on the gigaport sound card and its the same. :-(
Please Help
Processors: 1
L2 Cache: 3MB
Memory: 1GB
Bus Speed: 800Mhz
Please Help
geposted Sat 15 Oct 11 @ 5:59 pm
You can see here the Mac System Requirements
https://virtualdj.com/products/virtualdj/
Skipping is in most cases a problem with the used soundcard, but also check this.
https://virtualdj.com/wiki/Common%20Mac%20Performance%20Issues.html
If possible, test a DJ soundcard from a dealer in your area.
geposted Tue 18 Oct 11 @ 9:19 am
