Hi all,
I'm new here. I just download home ver to play. I used to mix through the dj equipment + external mixer 10 yrs ago. But on PC, this is the first time. I try to use the mappers to define the hot keys. I find the difficulty when I use the mouse to raise the level (volume) of any deck on the internal mixer while mixing. For more convenience, I would like to define a key to gradually increase the volume (level) of the deck 1 by % or number, but unfortunately I cannot do it as I can't find the proper command. May I need your help to sort this out. Thks in advance.
Catty
Catty
geposted Sun 16 Oct 11 @ 7:30 am
iv done a 3 hr mix that way, it was easy but now i use my CDJ decks that are midi controlled and my cdj 350 or 400 mixer.
thanks pete
geposted Sun 16 Oct 11 @ 7:59 am
your limited to use of config coz you have the free version, if you upgrade to pro you will have access to all configs and settings .
thanks
thanks
geposted Sun 16 Oct 11 @ 8:02 am
did you check this out:
https://virtualdj.com/products/comparison.html
geposted Sun 16 Oct 11 @ 8:05 am
