Is there any way to show the key of a song as you are searching in the browser?
Thank you
Thank you
geposted Sun 16 Oct 11 @ 9:30 pm
go to your searchbar and right click the box to the left.
now select key and there you go
geposted Mon 17 Oct 11 @ 4:03 am
Also you can select Key(Numeric) in order to see the Camelot Mixing System numbers that would be a lot easier for you to understand than standard keys (unless you have music theory knowledge)
geposted Mon 17 Oct 11 @ 6:48 am
So what about if that doesn't work. I checked Key and it doesn't show up at all?
geposted Mon 17 Oct 11 @ 9:58 pm
It works like any other database browser, just go to the top of the browser colunms, right click and select Key(Numeric) as phantom said and your done...
geposted Tue 18 Oct 11 @ 2:25 am
The files need to be scanned by VDJ in order for a key and BPM value to be present.
geposted Tue 18 Oct 11 @ 5:22 am
Thank you for all your help.
geposted Sun 23 Oct 11 @ 10:34 pm
