Is it possible to set hot cues with the effect keys on my hercules rmx?
if so, how do I do this? thanks
also: I currently have my pitch slider set up to control effects, but it only controls p.1 of the effects, which is generally the volume. is there a way to map it so that the slider controls p.2 instead? thanks
geposted Mon 17 Oct 11 @ 2:34 pm
Yes you can I did it with my all 6 of mine + the Bass also,You may need to buy the VDj-Pro to map and change the RMX.
geposted Wed 19 Oct 11 @ 5:04 pm
