Hi,
I've searched around and haven't found anything. Is there any way to make the cue point marker when you are using automix to be bigger so that it is easier to grab on to and move? I don't care if it's a new skin, or just some kind of add on.
Thanks for any help you can give.
DaveHoyt
DaveHoyt
geposted Tue 18 Oct 11 @ 12:33 pm
Yup. Under the skin .XML, look for the deck number and <cue> size. Increase the width and height to your liking. Then, edit the skin .BMP, find the X,Y location of the cue marker, and increase the size there by adding more "black" to thicken it up.
I went through the same thing and had to double the size of the markers and the wave pattern. Trying to squint and see where you are in the night when the crowd is bumping and the drinks are pouring requires superman concentration!
geposted Wed 19 Oct 11 @ 11:37 pm
