Hi Everyone,
I have the standard two deck skin.
Instead of the two red and blue rhythm waves overlaying each other;
I would like to split the width of the main rhythm wave panel in half and have the left deck's blue waveform on the top half of the panel, and the right deck's red waveform on the bottom half.
The height of each rhythm wave will probably have to be shortened.
The original cue and beat marker 'pos' for the top rhythm wave will also need to be moved.
Any help on how to change the default XML skin for this modification?
Thanks,
Clay
Thanks,
Clay
geposted Thu 20 Oct 11 @ 6:46 pm
which skin is it? most skins available here at downloads have multiable wave layouts.
geposted Sat 22 Oct 11 @ 12:55 am
I am using the default 7.0.5 Pro 1280x768 skin.
Currently when two decks are playing, both waveforms (blue and red) overlap each other.
I would just like to split the two waveforms and put one on top, and one on the bottom of the main rhythmwave panel.
Thanks for your help.
Clay
Clay
geposted Sat 22 Oct 11 @ 9:49 am
