Forum: VirtualDJ Skins
Topic: [NEW] Default 4 Deck SWAP - Page: 2
you did a great job. Did you found the reason for the booting delay? I have same effect on every VDJ start.
Vers. 2.0 please in 1280x800
Good news...
I found the bug responsible for the delay when loading then skin.
Ver 2.0 final, will be uploaded very soon.
I need to apologize to those who downloaded the skin. There was a size limit in the uploaded file, which i forgot, and the above link was about the old version.
So i had to split the skin into 2 files...
High resolutions HD(1600x900 1920x1200 1920x1080) are available here ...
https://virtualdj.com/addons/13812/VirtualDJ_7_(4_Decks_Swap_HD).html
Lower resolutions (1280x800 1280x1024 1366x786 1440x900) are available here ...
https://virtualdj.com/addons/14226/VirtualDJ_7_(4_Decks_Swap).html
Please re download the file you need.
Thank you.
Bob,
That skin is AMAZING!
I'm using it in 2 deck mode which gives more browser room and I only need 2 decks anyway!
I've modified a few things in the XML and there's a hell of a lot of coding gone in to that one.
Cheers
Keith
Thank you very much, is excellent.
Hi DJDad, I try this skin and I find it had a great features.
So, while using video features on all decks, I notice that if I play out a video from deck 1 and I swap between 1-3, the output video master switch to deck 3, so the played Deck 1 video disappear from master out video; for me this is a problem. This functionality it's by design or it's a bug of VritualDJ ? It's possibile to assign wich video remain on master video ?
Also, I'm working with Denon DN-MC6000 and with this skin, the sequence of slide on controller are 1-2-3-4, but in the skin the mixer are visually set Deck 1 on slide 2, Deck 2 on slide 3, Deck 3 on slide 1 and deck 4 on slide 4. It's possible to have a skin or a configuration of my controller to respect the same sequence of slider ?
Anyway, this skin it's very good and compliment for hard working of coding this complex XML script !
Thank You in advance.
Best Regards
El Puma DJ
You can assign whatever deck-video you wish to have as left or right (ready to mix), using the CH assign buttons (1...4) when video crossfader is visible in the video panel.
Most of the controllers have the deck order 3,1,2,4. MC6000 can work like this too. A version with 1,2,3,4 mixer order is not in the present plans.
Thank You for fast reply !
I had tried the skin CH assign buttons (1...4) when video crossfader is visible in the video panel, but doesn't work; when I swap deck 1-3 when one of this it's play out, the master video out change to new swapped deck, without respect any combination of above setting. Same thing when swap deck 2-4. This happen with PC version and Mac version too. What's wrong ?
For the sequence of the slider deck on DN-MC6000, if I want to align with your skin there's a way to do it ? For example to remap the console configuration inside Virtual DJ ?
Best Regards
El Puma DJ
Hello, any news or workaround about video swap 1-3 (or 2-4) issue ?
Thank You in advance for attention.
I will try to explain how the video works in a 4 deck mode.
Each time you press the swap button, or swap the decks using a button on your controller, the small video preview windows follow the decks.
That is regardless on what you have assigned the CH video crossfaders.
The CH assigns for the video crossfader are by default OFF. On that position, the deck that shows up in the master video output is always the one on the top (leftdeck or rightdeck)
If you manually assign a deck to be the left or the right video output, by choosing one of the CH buttons, then the above automatic assignment stops, and you need to manually set each time which deck you wish to be outputted.
In order to set the video CH assign back to automatic change (to follow the leftdeck or the rightdeck), simply rightclick on one of the CH assign buttons.
I am not sure how your controller is mapped, but the way the skin is made works with all the controllers that follow the left-right logic.
Oh, now I understand what do you mean; now I know clearly this functionality and it's work great. Thank You for explanation and for this great skin !
Best Regards
El Puma DJ
Hi and before anything else...
Thanks for creating this skin...
It's what I have been looking for...
Here are few this I have change for me and a couple on items I found I don't know how to fix...
I changed the font style, size and color under ---tiime---
Font style to "arial", sixe to "19" and color to "Yellow"
I want to able to see the time easier...
Here is what I don't know how to fix:
When I select "Decks" to change from 4 to 2 I get an image along the bottom of my screen...
I looks like part of the video mixing board...
Lastly, I would like to be able to increase the browser maybe to "10" or maybe even "12".
Please let me know under which heading I can find the switch size.
Short of these couple of items I really like your skin...
BTW: I'm using 1024x768 version... Sorry, I know I should get a bigger laptop screen... :)
OK, for now here is what I did to get the browser font so I read it easier... (For Me)... :)
Under the <browser panel....
I change all the font sizes to "14"
I can read very easy now...
If you not able to fix the decks switch image along the bottom it's fine...
I wanted 4 decks, so it's doing what I have been looking for...
Great skin and it is one I will be using...
Thank you, thank you, thank you....
:) one happy CadDog ready to rock with 4 decks with an little old laptop... :)
Updated ver 2.1.1.
(for resolution 1024x768)
- Graphic bug corrected on 2 deck mode
- Browser font sizes are now from 12 to 15
Thanks for noticing that.
..and yes, you should get a bigger screen :)
djdad wrote :
Updated ver 2.1.1.
Thanks djdad, I find it fun to work with code...
With a second look I was able to fix the Graphic bug by editing the bmp...
A little cleanup did the trick... ;)
However, Since I don't do videos it does hurt me but I like to let you know what I just found.
While play a video on player 1, then loading a second video on player 2
the center video screen looks like it zooms way in and your not able to see the video playing anymore.
I try it with both 4 and 2 decks and the same thing happens...
If I close and ope vdj I can again play a video on one player...
Again, I don't video but I thought I let you know about this.
(This is on 1024x768)
Take care and again great skin.
Please keep up the great work because
while I'm able to edit skins I'm not able to create one...
CadDog... :)
Sorry but I don't have the $$$ to get anything new... :(
Hmmm you lost me here :) A screenshot could help maybe. Same thing happens with other skins as well ?
It seems that its related on the selected transition. Can you see if that happens when choosing a different one ?
Wow....
I just try with other skins and the same thing happen...
both play 1 and play 2 show the video play right
but the center screen show a zooms in version after
I load the second video into the next player...
I can't fix without reopening VDJ...
What could be doing this...
I haven't seen this before...???
My Bad....
It wasn't your skin at all this time...
The key word was ZOOM... lol
It was an effect which was being effecting the image on the center video player...
Sorry...
But I did say I didn't play videos... :)
I just didn't it to test your 4 player video....
Back to your skin work and sorry for my mistake...
CadDog back to playing music... :)
41%
