Ok...i bght a denon mc6000 came with virtual everLE...Installed latest version....It works fine but when hit config button get message "virtual dj has stopped working....windows 7 will close the program"...then I have to restart everytime...Can anyone please help?
geposted Mon 24 Oct 11 @ 10:58 am
Im running windows 7 64 bit....4g ram...low cpu usage when running LE...installing/installing 3 times...ive even tried downloading the free version get same error...ive tried power option suggested by vdj supp...last thing they suggested use a diff browser to d.. load prog....i used chrome
geposted Mon 24 Oct 11 @ 11:10 am
Have you registered your 6k with Denon and updated the firmware and drivers for it?
www.denondj.com
www.denondj.com
geposted Mon 24 Oct 11 @ 12:38 pm
Yes I have...
geposted Mon 24 Oct 11 @ 12:51 pm
Do you have Torq installed?
geposted Mon 24 Oct 11 @ 1:15 pm
Yes I do..
geposted Mon 24 Oct 11 @ 1:29 pm
For some reason Torqs rewire capability doesn't play well with VDJ.
You can either uninstall Torq or remove/rename ReWire.dll in the Windows\System32 (or possibly SysWow64 for x64 Windows).
geposted Mon 24 Oct 11 @ 3:40 pm
Thank You SBDJ...That worked...Sucks though cuz i wanted to use both vdj n torq 2.0to see which one was better for me...Appreciate the help...
geposted Tue 25 Oct 11 @ 10:04 am
