I was changing some of the mappings and got screwed up so I did a mappers reset, now my touch sliders dont scroll through the tracks or folders anymore. I really liked and would like to make them work again.
Not sure why it doesnt work anymore but I\'d like it to........any help would be great
Huey
Heres what the mappers says,
Huey
geposted Tue 25 Oct 11 @ 1:43 am
Also they are sending midi signals cause I have them mapped to do the samething with another program.........
Please any info
Huey
Please any info
Huey
geposted Tue 25 Oct 11 @ 2:22 am
L_Touchslider - normal work of the left slider - browser scroll
S_L_Touchslider - Holding Shift and using left slider - nothing
So the L_ stands for the left, R_ for the right slider. The S_ means while holding the shift button, too.
STRIP_BTN means that when you only TAP on the slider it works like a button - to open / close folders in the folder tree.
If you speak about the param_multiply in the action - it tunes the sensibilty of the stip because they are moving very fast without this.
Greets, Heiko
Greets, Heiko
geposted Tue 25 Oct 11 @ 5:55 am
So it would seem that all the script is there yet it dosent work. Why is it not working??
Is that the original script that comes stock?? I had DJDAD's mapper installed but deleted it could I of deleted the wrong mapper??
Huey
EDIT..... I had to delete DJDAD's def file aswell, so now its all good!!
Thanks for looking and your help.
Huey
geposted Tue 25 Oct 11 @ 6:54 am
One more thing, in this other program I have assigned the sliders mapped the same way as VDJ (browser scroll). With that program you press "c" to change how the scrolling works. Anyways with theirs I have it set to "Absolute", now when I scroll down it will still scroll once I let go. To make it stop I just slide my finger back up and it stops. I have a ton of control verses VDJ. My question is, does this have something to do with the "note" or "cc"?? I don't have a clue what those mean and have only seen them with my NanoKontrol. Is there anyway this can be checked on?? The other program is Serato. I'm no programmer but how ever its implemented with there's is the way I'd like it to work with VDJ.
Could a hardware expert look into this, please.........
Huey
Huey
geposted Tue 25 Oct 11 @ 8:56 am
Huey, you can try and make your self some absolute zones but I don't think it will work ...
Put this for the R_TOUCHSLIDER >
param_smaller 15% ? repeat & browser_scroll -1 : param_greater 85% ? repeat & browser_scroll +1 : param_multiply 0.02% & browser_scroll
geposted Wed 26 Oct 11 @ 12:52 pm
Well I tried it and your right it didnt work, anything else I can try.........
Thanks for looking and the time
Huey
Huey
geposted Wed 26 Oct 11 @ 5:39 pm
