OK, Since we are getting no where with the Numark Rep's in fixing the underwater worble sound in VDJ on the NS7 or V7, I went ahead and boot camped my Powerbook on anoer partition and installed Windows 7 Home Premium. actually it is kinda cool, i did a 20 gig partition for Windows and it shares the media folder on the Mac partition so I dont have to double up on stuff.
So what are some Windows settings to optimize Win 7 for VDJ? It is the only program I will be running. I already turned wireless off, but I remember a bunch of settings to tweak XP to run cleaner, what about W7 for my V7's?
geposted Tue 25 Oct 11 @ 10:11 am
These might help you mate,
https://virtualdj.com/homepage/ianmelville/blogs/4540/WINDOWS_7_OPTIMISATION_FOR_VIRTUAL_DJ_GIG_LAPTOP_.html
and
https://virtualdj.com/homepage/ianmelville/blogs/4560/Optimize_Your_Windows_PC_for_DJing__videos_Pt_1___Pt_2.html
Also have a look here
https://virtualdj.com/wiki/Performance%20Issues.html
https://virtualdj.com/wiki/Video%20Memory%20Issue.html
Never tried these with a bootcamp Mac though.
Hope it helps
and
Hope it helps
geposted Tue 25 Oct 11 @ 10:15 am
I would say follow the 2 post that ianmelville posted on here they both helped me out very much as i use the NS7 and it helped out alot. The NS7 is a CPU hog and when I used the 2 guides that ianmelville posted I was able to use my NS7 and windows 7 with no issues. Follow those 2 post and you will be set.
Charlie C
Charlie C
geposted Fri 28 Oct 11 @ 9:17 am
