I just installed Virtual DJ Home 7 (Free). How do I Beat Tap? For example, the song on deck #1 has 90 BPM. I manually beat tap to 120 BPM, but the speed (tempo) of the song does not change !!!
geposted Wed 26 Oct 11 @ 8:24 am
it doesn't have that ability, it only allows you to change the computer beat grid if vdj incorrectly estimates the bpm and the grid position markers, to change the speed the song is playing you need to move the pitch slider down..
you could probably activate the pro trial and map something like
'beat_tap & sync"
not sure if it would work though..
'beat_tap & sync"
geposted Wed 26 Oct 11 @ 9:08 am
