Hi everyone.
I Have got a Hercules DEEJAY TRIM 4&6 Sound Card. Please can someone help me with the setup to get it to work with Virtual DJ. I dont use a midi controller I plug it straight into a Mixer. What i want to know is how can I listen to the other deck through the sound card. Or do i have to have seperate phono leads coming out of the sound card into the mixer. thanks
geposted Wed 26 Oct 11 @ 10:12 am
you just plug the phono (turntable) outputs into the dj trim phono inputs and make sure phono is selected on the switch if it has one, then run the line out of the trim into your mixer channels and make sure line is selected on that.. then just use the pfl on your analog mixer like normal.
if you really want to use the dj trim headphone output you can set it up in advanced config but you will need to select the pfl deck in vdj either with a midi controller or your keyboard or mouse.
geposted Wed 26 Oct 11 @ 10:40 am
