Hi,
I wonder if it's possible to change the loop value without manually click on 4, 2, 1 etc? For example if I want to loop 4 strokes, then 2 strokes, then 1 etc. etc. You know the usual techno "build-up to a drop" thing. Do I have to click on the loop buttons or is there a way to set these different loops automatically?
geposted Wed 26 Oct 11 @ 8:50 pm
Yes, it is possible. In the keyboard mapping on the Virtual DJ, the keys 1, 2 and 4 do this for you. Anyway here's the code to do this.
Key - Code
1 - loop 1
2 - loop 2
4 - loop 4
Key - Code
1 - loop 1
2 - loop 2
4 - loop 4
geposted Wed 26 Oct 11 @ 11:03 pm
Thank you for the answer!
I know how the loops work and that I can use my keyboard for the loops but my question is how can I set different loops after each other?
http://www.youtube.com/watch?v=dg7XO1zgJHA
0.24. You know that kick going faster and faster. 1/4 notes, then 1/8, 1/16, 1/32 etc etc. Would it be possible to do that loop sequence assigned to one button on the keyboard? I don't want to push 8 to cut the loops in half.
geposted Mon 31 Oct 11 @ 4:42 pm
If I understand right, you want a button that always break the current loop in half and in half again.
You can set a key with the code "loop_half." He will break the loop in half by the minimum allowed.
geposted Mon 31 Oct 11 @ 6:46 pm
kaleo made a plugin called looo games that can play the loop then mute the second time, not what you want but shows it could be done if you know how to use C++
geposted Mon 31 Oct 11 @ 9:32 pm
Where can I find that plugin and where can I learn about C++? I have searched but couldn't find anything.
Wouldn't it be possible just typing in some VDJscripts in the Action-Learn box and then assign them to a button on the keyboard?
For example if I want 4 bars of 4 loops and then 2 bars of 2 loops. What do I type in the Action-Learn box?
geposted Tue 01 Nov 11 @ 7:45 am
you need to be a registered pro to get loop games, and it cant be done in script as every action is done immediatly when you hit the button but as stated ealier you can just use loop_half and press it when you want to halve the loop
I found heaps on c++
http://www.google.com.au/search?q=c%2B%2B&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-GB:official&client=firefox-a
geposted Tue 01 Nov 11 @ 7:57 am
