Hello,
I recently bought a Hercules RMX and am very happy with it.
I remapped the "Down" key like so:
toggle 'shift'
it worked well,
but when press the down key on the RMX i would like it to say on screen "Shift on" or "Shift activate" or something
what would i need to add to the down key's mapping to do that also?
Thanks in Advance,
Senan.
toggle 'shift'
it worked well,
Thanks in Advance,
Senan.
geposted Thu 27 Oct 11 @ 12:16 pm
I have not had this problem with shifting. What I would suggest is that (first after waiting for a better response :P)
-Double check that you have the right script written: should look something like this : set **non shifted value ;$shift***shifted**; 1 while_pressed
-Try it on another key
-reinstall vdj.
good luck
-reinstall vdj.
good luck
geposted Mon 31 Oct 11 @ 10:41 am
@Sentriz:
You can't do it with textzones.
You have to do it with pannels.
You should an empty space on your skin.
Then create two graphics, one for SHIFT pressed and one for SHIFT not pressed.
Finally you have to add this code:
<pannel id="SHIFTON" group="SHIFT" visible="var_equal 'shift' 1 ? on">
<size width="70" height="20"/>
<pos x="550" y="100"/> <-This is the location of the empty space on your skin
<down x="550" y="3000"/> <-This is the location of the graphics when the SHIFT is pressed
</pannel>
<pannel id="SHIFTOFF" group="SHIFT" visible="var_equal 'shift' 0 ? on">
<down x="550" y="3020"/> <-This is the location of the graphics when the SHIFT is NOT pressed
</pannel>
</pannel>
</pannel>
geposted Mon 31 Oct 11 @ 1:31 pm
