program will not seperate decks-still hear both from one line-what am i doing wrong?
my set up is
input-none
output=external mixer
soundcard-mono seperated
my set up is
input-none
geposted Thu 27 Oct 11 @ 5:42 pm
I don't think your LE version supports an external mixer.
Huey
Huey
geposted Thu 27 Oct 11 @ 5:56 pm
it shows on my laptop so i think it does support it
geposted Thu 27 Oct 11 @ 5:59 pm
VirtualDJ Basic does support separate decks to an external mixer - See http://www.virtualdj.com/products/comparison.html
If you are using the mono separated option with a Y splitter cable, then you probably have the wrong type of splitter. You need a cable that splits the signal into two MONO signals (Left and right.) You probably currently have a headphone sharing adaptor which splits the output into two identical stereo outputs. This will not work for the mono separated option.
NOTE: For live performance, a proper multi-channel DJ sound card is recommended such as Numark DJIO. This will give you stereo sound for each deck.
geposted Fri 28 Oct 11 @ 3:19 am
what do i need to use the two sound cards together--my comp sound card and the creative x-fi go pro
geposted Fri 28 Oct 11 @ 9:45 am
^ yes, go pro
geposted Tue 15 Nov 11 @ 8:04 pm
