Some songs in VDJ are remembering the effects used before.
For instance, I have a song that a while back I ended it with a slow break. Now when I play that song again at the end it does the same thing. When I take this same FILE song and play it in iTunes it sounds normal.
Other songs that I've used the "beatbreak" have also remember where I had used it, and then I'm playing it again days later and it automatically does it again.
Is there any setting to turn this off?
The frustrating part is that it doesn't happen to all of the songs, only some.
MacBookPro13
VDJ 7.05
Thanx
MacBookPro13
VDJ 7.05
Thanx
geposted Thu 27 Oct 11 @ 10:52 pm
It's in the configuration settings, reset effect on load (or something similar)
Keith
Keith
geposted Fri 28 Oct 11 @ 1:16 am
Please also see https://virtualdj.com/wiki/Effects%20still%20activated.html
geposted Fri 28 Oct 11 @ 4:05 am
Thanx for the replies,
although my settings are to 'FX reset on load"
geposted Fri 28 Oct 11 @ 3:50 pm
