I was playing a track on deck 1 and at the same time played a sample in a loop. I tried scratching on the jogwheel and noticed BOTH the track and sample was being scratched at the SAME TIME? What I would like to see for the upcoming build is if there will be a new feature that can seperate scratching the track with the sample.
geposted Fri 28 Oct 11 @ 1:34 am
Perhaps by way of a Plugin called Sample Scratch?? if u activate the sample then u can scratch ONLY the sample being played BUT if you have more than one sample i guess it will not work.
geposted Fri 28 Oct 11 @ 5:28 pm
or something in CONFIG settings that says Scratch Sample Only??
geposted Fri 28 Oct 11 @ 5:31 pm
do u have beatlock on?
geposted Tue 15 Nov 11 @ 8:54 pm
it's your settings mate... "cough pc/mac tech support cough"
geposted Wed 16 Nov 11 @ 12:16 am
