So Windows Media player makes a bunch of sub-folders when ripping CDs.
It seems Virtual DJ won't recognize any of these tracks until each and every folder is opened within the program.
Is there any way to have Virtual DJ's search function find songs that are in a sub-folder without having to open up hundreds of subfolders first?
geposted Sat 29 Oct 11 @ 3:53 am
My guess is that if you right click the parent folder and the select "Add to search DB" then the child folders will also be added.
You can then right click the parent folder again and select "Recurse" to make the parent folder seem to contain all the songs in the child folders as well.
geposted Sat 29 Oct 11 @ 4:26 am
