I'm used to that vynal feel where after you scratch you give the record a small push. How would I change the speed of it or disable that speedup VDJ uses when I release the scratch using touch sensitive jog wheels? Thank you.
geposted Mon 31 Oct 11 @ 7:57 pm
this is how it would work if it did work, but it doesn't... or maybe my lappy doesnt have enough power cause it glitches out...
you will need the tts (turn table start) effect if you dont already have it and i could never get the newer "brakestart" effect to do it...
map the touch part to this
down ? touchwheel_touch 1 & effect "tts" active off : touchwheel_touch 0 & effect "tts" active on
then play with the settings in the plugin to alter the spool up speed
geposted Mon 31 Oct 11 @ 9:01 pm
It's a PC only plugin...
geposted Mon 31 Oct 11 @ 10:17 pm
