Hello all.....I am recently gettings back into the DJ scene and wow is all I can say with how much has changed from the conventional 2 decks(cd's, records, and/or 45's) and a mixer to multiple decks and everything being digital....I recently purchased the numark mixtrack pro deck to just get started and back in the game. I was wondering if there was a way to add a tabletop controller to have 3 decks. I have virtual DJ pro, so I know the software supports it, I was just wondering how I can connect the hardware and what additional hardware is needed. any and all information/insight is appreciated.
Thanks all
Thanks all
geposted Tue 01 Nov 11 @ 10:29 am
You can simply add a single deck CDJ-style controller such as Denon DN-S1200. This will allow you to control a 3rd deck.
VirtualDJ Pro allows multiple MIDI controllers to be used at the same time.
You can assign the controllers to the appropriate decks in CONFIG -> Mappers - See https://virtualdj.com/wiki/Decks%20inverted%20on%20MIDI%20controller.html
geposted Tue 01 Nov 11 @ 10:44 am
