I have a gemini 3600 dual cd mixing console it has 2 line inputs, if I get a 4in 4out sound card to hook up to the laptop, plus the cd's etc. will I be able to run timecode on this thing? Thanks in advance!
geposted Tue 01 Nov 11 @ 11:49 am
yes, alot of people go with a maya44 soundcard for a cheap set up, and you will need VDJ pro to run timecodes.
geposted Tue 01 Nov 11 @ 6:44 pm
oh ok so can I use the free version to test it out or does the timecode only work with the pro version?
geposted Wed 02 Nov 11 @ 9:31 am
Only the pro version supports timecodes, now if your CDJ's are USB, then that may be a different story (but i'm pretty sure only the pro version allows custom midi mapping as well)
There is a trail period for the pro, and if you have bought gear that includes VDJ, there is a pretty good chance you can get a discount.
geposted Wed 02 Nov 11 @ 2:16 pm
Pro features such as timecode and MIDI controllers can be tried for 10 minutes at a time in Home FREE.
After that, it reverts back mouse/keyboard only, but you can restart the software to get another 10 minutes trial as many times as you like.
geposted Thu 03 Nov 11 @ 11:14 am
