Forum: Old versions
Topic: Crossfader working incorrectly!
I have VirtualDJ LE and a Numark Mixtrack (not the pro version). The crossfader in VDJ LE is functioning incorrectly. Instead of just fading from one deck to the other, this is what happens:
I'll load one song in Deck A and start playing it. Even if I have nothing loaded in Deck B, when I start moving the crossfader from the left to the right, the volume on Deck A starts going down. Once I get to the middle of the fader, Deck A is at half-volume.
This is a huge dilemma for me because my mix gets quieter whenever I transition between songs. Can someone please help?! I have a show this weekend and I can't do it unless this gets fixed.
Thank you!
geposted Tue 01 Nov 11 @ 3:01 pm
i just recently got the VMS4 and installed the Virtual DJ that comes with it, and i notice when i use my Speakers and Headphones when i move the Crossfader the sound moves in both Speaker and Headphones,
HELP!!!!
Thank you!
Unfortunately you can not change the crossfader behavior with the LE version. You can do that with the Pro Full version which you may get with a large discount. https://virtualdj.com/products/oem.html
Alternatively you may use the deck volume faders to mix instead of the crossfader
HELP!!!!
What LE version do you use ? Check that in your Config setup window
