Okay my fellow DJ's simple question but I need your help.
I have a club gig this friday.
There set up is a rane ttm57.
My question is can I plugin my hercules Mk4 to an output of the rane ttm57 using standard RCA's ?
Thank you,
Mike
Thank you,
Mike
geposted Tue 01 Nov 11 @ 3:40 pm
input*
geposted Tue 01 Nov 11 @ 3:53 pm
Yes, you can plug the master output of your MK4 into a spare channel on the club's mixer. You will still need to do your mixing and headphone pre-listening in VirtualDJ using the MK4 as you would do normally.
Alterantively, if you wanted to use the club's mixer instead of the software mixer of the MK4, then you would need to upgrade to the full VirtualDJ Pro to be able to use the Outputs: External mixer option. This allows you to output the sound separately for decks 1 & 2, so that you can plug each into a separate channel of the club's mixer.
geposted Wed 02 Nov 11 @ 7:14 am
Thank you so much sir!
Okay yes I have VDJ pro. I want to use my Mk4 I feel more comfortable with it. Okay so which channel should I plug it into the AUX? PGM1? PGM2?
geposted Wed 02 Nov 11 @ 5:40 pm
AUX......
geposted Wed 02 Nov 11 @ 6:09 pm
