I just purchased the Gemini CNTRL 7 and having some problems with virtual dj with scratch mode and playing the music.
example: when the song is currently playing, i select scratch mode (the scratch button will be light on) i will then move the jog wheel back and then make the scratch sound. when i let go of the wheel, the music would stop. to play back the music, i have to disable scratch mode off.
is there a way to have the music keep playing after i let go of the jog wheel. i like to have it set up as to the vinyl style of moving the wheel.
im not sure but im thinking it has to do with the Config: Mappers.
Under Config:Mappers:Scratch the action key is "wheel_mode "search" ? wheel_mode "jog" : vinyl_mode"
any advice would help.
thanks,
andrew
thanks,
andrew
geposted Wed 02 Nov 11 @ 12:20 am
