Hi,
I have VDJ Pro set up with a Deejay Trim 4&6 running into two Numark ICDX decks and a Numark Dxm03 mixer. The main problem I'm experiencing is that when I mount two different songs onto two separate decks in VDJ it will only play one of the songs on both decks. If I click play on both of the songs in VDJ then it plays both out of the speakers but it doesn't display two separate songs on the CDJ's.
Any Help with this will be much appreciated
Thanks.
Thanks.
geposted Sat 05 Nov 11 @ 5:21 am
