Hey guys,
I'm struggling coming up with a solution to this.
Basically, I am creating my own MIDI controller with software on the computer. I'm sending VDJ a MIDI value of either 1 or 0 and I would like to check the value and do something different depending if it's 1 or 0.
so something like
midi_value 0 ? deck 1 play : deck 2 play
I'm just not sure the proper way to reference the midi value being received.
Any ideas on how I can do different actions depending on the incoming MIDI value?
Thanks guys,
Tyler
so something like
Thanks guys,
Tyler
geposted Sun 06 Nov 11 @ 5:22 pm
I am going to assume you are using buttons and the buttons are using CC not NOTE -
So in your device definition file you would define the buttons as follows:
<button cc="0x01" value="0" name="PLAY1" />
<button cc="0x01" value="1" name="PLAY2" />
Then you will have your mapping as:
<map value="PLAY1" action="deck 1 play" />
<map value="PLAY2" action="deck 2 play" />
Read here (if you haven't already) - https://virtualdj.com/wiki/ControllerDefinitionMIDI.html
geposted Sun 06 Nov 11 @ 8:34 pm
