Forum: Old versions
Topic: adjusting the pitch fader with hercules rmx
anybody know how i can adjust the pitchfaders to say +/- 10%.
using vdj 7 and hercules rmx.
thanks!
geposted Mon 07 Nov 11 @ 3:30 pm
Click on the range button in the skin. Not sure if it can be done from the unit itself unless you mapped it. You should also register your software to take advantage of the free goodies here ;-)
Good Luck
Huey
Pitch range can also be changed in CONFIG -> Options
You will need to purchase the full VirtualDJ Professional to use the RMX with VirtualDJ v7 (The RMX comes with v5 Console Edition.)
Assuming that it is not second hand or the discount has not already been used, your RMX DJ Console entitles you to a significant discount off upgrading to the full VirtualDJ Professional. To receive this, please go to https://virtualdj.com/buy/ and enter your DJ Console software serial number in the box provided.
