Hello all,
I am trying to pull off a manual loop using my MixDeck, but when I hit the Loop in button and i'm 2 beats past the loop in point, it cancels my loop. as soon as i hit loop out at the point i want to reloop, it cancels, and autoloops at the exit point instead.
the mapper was not touched as far as the loop buttons are involved
HELP!!!
Jerry.
HELP!!!
Jerry.
geposted Mon 07 Nov 11 @ 7:18 pm
Im thinking you would need to Update Your Stuffs .Software Aspect. ie. Virtual DJ, Mappers and all
geposted Thu 10 Nov 11 @ 11:40 am
VDJ is up to date, mappers are my own, and i havent messed with those buttons (as i stated in my first post). It cancels after 8 beats from hitting the loop in button.
geposted Thu 10 Nov 11 @ 1:49 pm
I will advice you to then ask The Officials of Numark for Help .. Folow this Thered for more Help.
https://virtualdj.com/forums/107208/Hardware_Technical_Support/NUMARK_Hardware_Products_(Setup__Solutions__Fixes__Issues__etc_).html
geposted Fri 11 Nov 11 @ 10:12 am
Right... So anyone else have an idea?
geposted Sat 12 Nov 11 @ 11:05 am
map another button to do the same thing. if the problem is still there map the keyboard of your laptop/pc to do the same. if the laptop have the same problem 1st check your map 2nd re-install vdj. the problem is at your midi device.
geposted Sat 12 Nov 11 @ 6:06 pm
