Hey!
First things first .. First Post!
Ok so moving on, My Numark Mixtrack Pro has been working fine the past few weeks with no issues and I recently received an AKAI MPK midi controller and now have a few problems. It seems after installing the AKAI MPK im not getting any responses from mixtrack pro even though it recognizes the controller in VDJ. Any thoughts? Im guessing driver issues? Im going to uninstall the AKAI stuff now and see what happens.
Cheers & Thanks,
Dave
Cheers & Thanks,
Dave
geposted Tue 08 Nov 11 @ 12:26 pm
Hey do you have any updates? I was planning to buy one also. My only concern is that the same thing would happen to my vestax if I would install it to my laptop.
TIA
TIA
geposted Wed 25 Jan 12 @ 12:42 pm
Well........any news??? Ive got an mpk25 and a numark misxtrack pro alsoc and id like to know if its possible to use both at the sane tine in virtual dj.
geposted Sat 14 Dec 13 @ 2:19 pm
Multiple controllers can be used with VirtualDJ at the same time.
The Numark MixTrack Pro is natively supported, but the Akai MPK is not because it is a musical keyboard rather than DJ controller. But there is a user-made mapper for it or you can map it manually yourself.
To be able to use either controller, you will need to purchase the full VirtualDJ Professional. If you like VirtualDJ, then please support the software and its future development by purchasing it (Especially if you are a working DJ and you are making money as a result of using it at your gigs.)
geposted Sun 15 Dec 13 @ 11:17 am
