I have my VJD Database.xml stored under "my documents" on C: Drive and I always make sure to bk this folder up......All of my music is
on E: drive and I'm getting another folder showing up in this location labeled VDJ Local Database.xml......Is this normal?....Why isn't the
VDJ Local Database.xml not saving in the main VDJ Folder on my C: Drive?...........If I try to bkup this Local Database.xml folder, I
browse to it on my E: drive and it does not show up in my backup utility, all of my normal albums and tracks do show up however......thnkx
guys.....
guys.....
geposted Tue 08 Nov 11 @ 10:23 pm
Basically for every drive you use with vdj there will be a database built for that drive. At least that's how I understand it works, lol!
Huey
Huey
geposted Tue 08 Nov 11 @ 10:32 pm
Exactly!
For EVERY drive (even a usb thumb drive) that VDJ browses, it creates a "VirtualDJ Local Database v6.xml" file on the root of the disk. This file holds the database for the songs contained on the particular drive.
The ONLY drive that doesn't get a "VirtualDJ Local Database v6.xml" file on the root is the SYSTEM drive that you will find a "VirtualDJ Database v6.xml" file on the C:\Users\USERNAME\Documents\VirtualDJ folder.
geposted Wed 09 Nov 11 @ 2:07 am
Exactly .. They all Right .. Anyways i wanted to know if those databases can be Joined and Combined.... Cuz Itz Hurty having a dB on a Drive and anoda One. I find them to be Plenty and also dont wana go back and scan for BPMs and what ever ... Any idea on how to join those db to ur Old ones to Keep on Rocking .???
geposted Wed 09 Nov 11 @ 6:15 am
You don't and can't join them. That defeats the whole purpose of the plug-n-use design of the database system.
The database concept is explained in pretty simple detail within the first couple pages of the User Guide.
geposted Wed 09 Nov 11 @ 7:03 am
Ohh I seeee... Do you have any Simple tool that i can use to Scan for ma BPMs for VDJ.. Using da Nornal Scan Slows down ma System at times
geposted Wed 09 Nov 11 @ 8:20 am
Sounds like you need to upgrade ;-)
geposted Wed 09 Nov 11 @ 8:22 am
You just need to scan what has no BPM numbers in the field...
A Quick lesson,
1. Put an Asterisk on the browser search field.
2. Click the BPM Tab to sort that field.
3. Scroll to where there aren't any numbers in the field.
4. Highlight all with no number in the field.
5. Right click and choose "Scan For BPMs"
6. This scans only what hasn't been scaned.
If you want to scan only what was recently imported,
1. Click and sort "First Sceen" Tab in the Browser.
2. Make sure the most recent files are on top.
3. Highlight those you need.
4. Right click and choose "Scan For BPMs"
5. This only scans what is needed.
Good Luck,
Joey....
geposted Wed 09 Nov 11 @ 10:58 am
WooooooW.. he Explained It Alll For me .. Thankx a Lot DJ JoeyKJ ... It Worked For me... Anyways what does those Asterisk Means .
geposted Thu 10 Nov 11 @ 11:14 am
Means "Everything in the Database" even the files that don't play....
Good Luck,
Joey...
Good Luck,
Joey...
geposted Thu 10 Nov 11 @ 5:04 pm
I will advice you to then ask The Officials of Numark for Help .. Folow this Thered for more Help.
https://virtualdj.com/forums/107208/Hardware_Technical_Support/NUMARK_Hardware_Products_(Setup__Solutions__Fixes__Issues__etc_).html
geposted Fri 11 Nov 11 @ 10:10 am
