Hi downloaded the free trial version to try out with time code vinyl. it works for 20 min which is fine for trying out. I was a long time Traktor user since version 2.6 in the early 2000s. WAnted to take VDJ for a tryout.
my set up is 2 1200s a vci-100 midi controller and a combo of 2 older SoundBlaster cards ( I sold my NI audio8) Is there any way that I can use "ASIO 4 all" free program to be able to use my older cards which are 5.1 but not ASIO. I using an adapter from my 1200s to the cards a female rca to mini jack to both cards card a using line in 1 and card b using line in 1. I can get one deck to work fine but I keep getting both software decks linked to same table. Went in to advanced config settings and for time code I only get 1&2 for decks 1 and 2 there is no 3&4
geposted Wed 09 Nov 11 @ 11:11 am
To do things properly, you need to buy a professional ASIO sound card instead of messing about trying to get things working with entry level consumer stuff.
ASIO4ALL is not going to magically turn your non ASIO card into a professional standard setup - it's a bodge to fool software into thinking an ASIO card is connected.
geposted Wed 09 Nov 11 @ 4:03 pm
