Topic: Legal question
If I sale my computer with vdj on it is that illegal? Do I have to delete it or could I add cost to the computer for it?
geposted Thu 10 Nov 11 @ 3:54 pm
VirtualDJ End User License Agreement
1. PERMITTED USE AND RESTRICTIONS
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
This license does NOT allow you to:
- rent, lease, sell, lend, distribute, publish, bundle or sublicense the Software or any part of it.
- rent, lease, sell, lend or distribute hardware on which the Software is installed, unless specifically authorised by Atomix Productions.
- electronically transfer the Software from one computer to another or over a network.
- decompile, reverse engineer, disassemble, or otherwise reduce the Software to a human-perceivable form.
- modify the Software or create derivative works based upon the Software.
Please have a look here for the full disclosure-> https://virtualdj.com/atomixproductions/disclaimer.html
In summary, no you cannot sell it.
VirtualDJ licenses are non-transferable and cannot be sold, transferred or given away to another user.
If you wish to sell your computer, you must remove VirtualDJ from it first.
its stuck on u like glue ppls
Thanks guys thats what I thought just wanted to make sure.
