http://screencast.com/t/UJDCyPsu6ZA
Hi everyone; I couldn`t do this with vdj7. All I want is that when I play one song in left deck I wanna be able to go right with a click and when I go song in left deck should change
geposted Fri 11 Nov 11 @ 3:48 pm
Automix was changed in version 5 ... you are showing version 4 in the video.
Automix is now only performed in 1 deck so the other deck is open to prepare a different track.
geposted Fri 11 Nov 11 @ 4:33 pm
I know but my customer wants to use it like in vdj 4 is there any way of doing it ?
geposted Fri 11 Nov 11 @ 6:32 pm
Tabatak wrote :
my customer
Why is your customer telling you how to use the software?
And if I make the assumption that you are supplying an 'on-site' solution to someone, then you need to read our End User License Agreement.
geposted Fri 11 Nov 11 @ 6:50 pm
Lets assume he is playing song in left deck in vdj4 he clicks automix button and it fades to right deck but song in left deck goes and new song from the list comes instead that one. all he wants is that. automix_dualdeck is doing it but if you want to change the song in the middle it doesn`t fade, it always fades end of the song
geposted Sat 12 Nov 11 @ 10:18 am
.....which is pretty pointless since we now have up to 99 decks!
LOL
geposted Sat 12 Nov 11 @ 10:39 am
You can still do that in Virtual DJ version 7 with more precise commands in the mappers. It is nice to see that both decks are playing rather than having it congested in on side of the deck. It is more improve than version 4&5 where it hangs up if the mp3 you are playing are having problems in reading while in version 7 it skips to the other tracks and it does not hang up and you can drop another song on the other deck if it stops playing.
geposted Sat 12 Nov 11 @ 11:11 am
You can still do that in VDJ 7.0 (it is called automix_dualdeck) it is not true that this option was remove by VDJ 7 it was made one deck in default. If you are using dj-controller you can assign buttons action="automix_dualdeck" />.
If you are using your laptop/computer you can do this by doing few steps below.
1. Go to CONFIG/SETTING select the "MAPPER" tab from the drop down menu select "KEYBOARD"
2. On the "KEY-LEARN" tab write (A) or any letters you like on the keyboard , this is the key you will use to press when you want to do the automixing with dual deck.
3. Then down on the "ACTION-LEARN" tab type this word "automix_dualdeck" and the press the green "+" sign under the keyboard shortcut commands window and press ok. Check if it is added on the keyboard command window where you can see all of the Virtual keyboard commands. If not repeat the same process.
4. Go to your VDJ, load the songs you want in the "playlist area" then press the letter "A" in the keyboard and it will run the VDJ 7 automixing with dual deck.
Cheers and Goodluck
geposted Sat 12 Nov 11 @ 11:13 am
Tabatak wrote :
...automix_dualdeck is doing it but if you want to change the song in the middle it doesn`t fade, it always fades end of the song
geposted Sat 12 Nov 11 @ 11:33 am
synthet1c wrote :
Yes you are right... and you have wait until it ends. But then you can do some to it like by doing some adjustments in the automix window on the following: Automix length: (0s, 2s, 4s, 8s, 16s,) Automix type: (smart fade, fade - intro & outro, fade - remove silence, fade nothing)
geposted Sat 12 Nov 11 @ 11:46 am
