I know there are alot of yal using the NUMARK NS7+VDJ video mixing, me not being a programer to map myself I used DJ ESCO's mapping for the NS7 for Vidz. But everytime I try to drop a quick sample, the platter starts playing when its not suppose to...sorry if doesnt make sense but that is the best way I can describe my problem....any advice??
geposted Fri 11 Nov 11 @ 3:51 pm
Well i have not used that mapper. But may I suggest gettin yourself the nsfx. The mapper for that lets you use the Nsfx fader as a video fader and has a auto fade button. Also good for sound effects. My NS7 and NSFX work excellent.
geposted Fri 11 Nov 11 @ 6:16 pm
Nevermind.......
Huey
Huey
geposted Fri 11 Nov 11 @ 6:30 pm
I have thensfx but i never used it because i didnt think it was compatible with VDJ...Do u know where i can get the mapper??
geposted Mon 14 Nov 11 @ 8:19 am
They are both supported nativley in VDJ 6.04+, no need for a map.
geposted Mon 14 Nov 11 @ 5:03 pm
I would say delete that map due to the fact that it would cause me issue too. but there is no need for it as it is natively supported already along with the nsfx. you can customize the vdj map that it creates to your liking by going to the mappers sections of vdj changing it to your liking.
Happy mixing
Charlie C
Happy mixing
Charlie C
geposted Mon 14 Nov 11 @ 5:18 pm
I have been using vdj + ns7 for video mixing for over a year and it has been rock solid. If you have any issues, remove mapper (no need for it) then do a factory reset of vdj in the config menu. You should be good after that as long as your computer specs are good enough. Good luck!
geposted Mon 14 Nov 11 @ 6:56 pm
thanks alot for the help guys I really needed it.
geposted Tue 15 Nov 11 @ 10:57 am
Rock solid NS7 and NSFX performace and video mixing for over a year as well.
geposted Wed 16 Nov 11 @ 8:36 pm
You guys with the NS7 running rock solid, wat are your computer specs?
geposted Wed 16 Nov 11 @ 9:34 pm
My NS7FX & VDJ be acting up.Going crazy.I really like 2 blend & scratch video.
geposted Thu 17 Nov 11 @ 12:00 am
intel core 2 duo cpu
e7400 cpu @ 2.8GHz
3 gb ram
windows XP
ATI radeon HD 4600
e7400 cpu @ 2.8GHz
3 gb ram
windows XP
ATI radeon HD 4600
geposted Thu 17 Nov 11 @ 12:46 am
windows 7 64 bit
intel core i7
6gb ram
nvidia optimus video card
intel core i7
6gb ram
geposted Fri 18 Nov 11 @ 6:57 am
Are those laptops or some custom built machines??
geposted Fri 18 Nov 11 @ 11:38 am
windows 7 64 bit
1.8 ghz i7 cpu
8 gigs of ram
ati radeon
Charlie C
1.8 ghz i7 cpu
8 gigs of ram
ati radeon
Charlie C
geposted Fri 18 Nov 11 @ 2:21 pm
Laptop or custom built machines please?? If its just a laptop what brand and model??
geposted Fri 18 Nov 11 @ 2:45 pm
samsung rc512 laptop
geposted Sun 20 Nov 11 @ 2:38 pm
me too...i use the esco mapping with some personal alterations. make sure u are configured correctly and using a skin for 2 decks
geposted Tue 29 Nov 11 @ 3:31 am
ibm lenovo i7 , 1gig video, 64bit, 6gb memory
geposted Tue 29 Nov 11 @ 3:34 am
