Hi All.
A newbie to VDJ, I was hoping to obtain an auto crossfader with buying the full version of Virtual DJ Pro Basic. Now that I have bought this full version I am concerned that it is no different to the free download version....with no 'auto crossfader'. Can anyone point me to how I get this fader set-up.
geposted Sun 13 Nov 11 @ 12:29 pm
you mean Auto Mix
or you want to use 2 decks to Auto mix
Map a Key to Automix_Dualdeck
geposted Sun 13 Nov 11 @ 3:12 pm
If you want to automatically crossfade between the two decks on demand, simply map a key to the action: mix_now
See: https://virtualdj.com/wiki/How%20do%20I%20map%20a%20keyboard%20shortcut.html
Some custom skins may also have a button mapped to this function.
geposted Sun 13 Nov 11 @ 4:09 pm
frenchy(66) wrote :
Hi All.
There's an auto crossfader in it, but you have to map it with the keyboard mapper and in your controller mapper or you can set a keyboard shortcut to activate the action="fader_start" it will allow you to crossfade and to automatically start the deck you are crossing in.
For your controller mapper try this:
<map value="FADER_START_A" action="deck 1 leftdeck ? deck 1 fader_start : deck 3 fader_start" />
<map value="FADER_START_B" action="deck 2 rightdeck ? deck 2 fader_start : deck 4 fader_start" />
geposted Wed 16 Nov 11 @ 3:56 am
