I'm developing a special skin for Virtual DJ.
I've a problem with chaining actions.
Tutorial says that to join several action we must use &
action 1 & action 2 & action 3
but in this case i don't know how to do this
<button action="loop" value="2" chan="1" >
<button action="play_pause" chan="1" >
<button action="deck 1 play_pause & loop" value="2" chan="1" > -->It doesn't work
<button action="deck 1 play_pause & deck 1 loop 2"> ->It doesn't work
I would like a macro to do a single button which concat this actions: First it will activate loop (2 beats) on deck 1, after it will play deck 1.
I've tried several codes and it's impossible to do it.
Another question that I haven't found in the tutorial is how to compare two values (not numbers)
Pseudocode
if (deck 1 eq_high > deck 2 eq_high) then action 1 else action 2
Thank you for your help. I'm trying to do my best!
Pseudocode
geposted Mon 14 Nov 11 @ 11:17 am
value="" and chan="" is not necessary anymore.
You can simply write
The above code will execute both actions at the same time. That means that it will actually make a 2 beat loop, and it will kepp looping until you press that button again.
What do you mean it doesnt work ?
As for your second question currently there is no easy way to compare those values. The current VDJscript only allows you to compare variables and values using param_greater, param_smaller etc.
geposted Mon 14 Nov 11 @ 12:49 pm
Thank you for your quick answer! That's good!
I think i tried that code but perhaps I made a mistake :)
I will try your code solution tonight.
Thank you.
Thank you.
geposted Mon 14 Nov 11 @ 1:47 pm
I'm usig the skin
MIX Station SV 04 (V2[1].00_edA).zip
Perhaps i'm doing something wrong or the skin is not right but this code
<button action="deck 1 play_pause & deck 2 loop 2">
<size width="42" height="42"/>
<pos x="469" y="388"/>
<up x="469" y="1823"/>
<down x="779" y="1272"/>
<selected x="779" y="1272"/>
<over x="779" y="1316"/>
</button>
doesn't work
On the other side, I have tried with the VirtualDJ7 default skin and the same code works great.
It's amazing!
What do you think should be the problem? Is because it's an old skin with?
</button>
doesn't work
It's amazing!
geposted Mon 14 Nov 11 @ 4:47 pm
Yes. On the first line of the skin you can see for which version of VDJ it was created for. If it was created for version 5 then chaining commands won't work.
geposted Mon 14 Nov 11 @ 5:24 pm
