Hi, I am a Macbook Pro 13 user and have been trying to download mixlab + other skins, i have carefully followed the guidelines on how to install the skins and i am 100% sure i am doing it right. I have uninstalled the program and reinstalled it (properly, deleting all files in Library, etc, etc + the actual ap.) When I load VD however.. i cannot use the new downloaded skin (which is in the correct folder.. Copied and pasted the .zip files onto User-Library-VD-Skins). Does any1 know a way to fix this or what the problem might be?
geposted Tue 15 Nov 11 @ 3:21 pm
You need to unzip the zip files and run/install the exe files.
geposted Tue 15 Nov 11 @ 5:44 pm
Not having a pro license will limit your access to skins and as it is a mac you will be restricted to the amount of plugins that are compatible.
geposted Tue 15 Nov 11 @ 8:39 pm
Tayla, as a Basic version owner, he has unlimited access to skins.
Just make sure you save the zip file to the correct Folder
Users\Username\Library\Virtualdj\Skins
geposted Tue 15 Nov 11 @ 9:14 pm
Thanks dad, I've been round here that long I still need help crossing the road... lol, wish my brain could update it's memory stick.
geposted Wed 16 Nov 11 @ 3:40 am
