I currently have a Hercules RMX and have been operating with this for the past 3 years. I want to upgrade to CDJs b/c I like the feel of being able to scatch more freely, but I am curious as to what purpose it will serve for me. I know most CDJs do not have USB input but I believe with Virtual DJ/Serato you can use the program to drag MP3s onto the CDJs. I hardly run off CDS when I DJ and lean more towards my external hard drive for playing music. With the Hercules RMX its basically "hook it up and go" therefore its easy. I have been looking at some CDJ-800s, but I dont want to waste my money on something I dont really need and if its something better out there for my needs I will apreciate your input. ANY INPUT! USB Preferred though, thanks in advance! Hope this isn't confusing
DJ TREEZ
DJ TREEZ
geposted Tue 15 Nov 11 @ 5:14 pm
Well the RMX you can attached cdjs and turntables and then use the rmx as mixer. I used to have a pair of Denon DN-3700s which almost felt like real turntable because of the 9" vinyl. And I attached it with the RMX. There also Numark V7 but it's not really a cdj. I'm sure there are cheaper CDJs but I believe the denon's have usb ready as well. Anyways I'm more of scratch dj (turntablist) so I choose to use turntables.
geposted Tue 15 Nov 11 @ 5:33 pm
I use a Numark Mixdeck, http://www.numark.com/mixdeck I'm not a heavy scratcher but it can be done. It can read CDs, flash/thumb/hardrives which is good cause you never know when the laptop will die. I really don't have any complaints about it other then the mixer section isn't MIDI. I just mapped a spare knob for my video crossfader.
There's a few different models,
http://www.numark.com/mixdeckquad
http://www.numark.com/mixdeckexpress
Happy Hunting
Huey
Happy Hunting
Huey
geposted Tue 15 Nov 11 @ 5:45 pm
Buy the denon Denon 3700's. I have a pair and they are really good. They have a usb connections and accept Usb thumb drives. The Platter feels better than The Pioneer CDjs and you are not paying alot of money for them. I have put the Denon decks thru soo much that they still perform well. I scratch, Cut, Blend etc. I highly recomend these decks.
geposted Tue 15 Nov 11 @ 7:08 pm
still weighing my options, keep the advice coming! thanks
geposted Wed 16 Nov 11 @ 2:47 pm
