Howdy folks. Just simple question that i should be able to fix myself but for the life of me just can't figure out....I Stream music to the virtual world of Second Life. When doing so I need to be able to hear the music playing from that application. How do I turn the sound down in VDJ without dropping the volume of the streamed music. IE..Mute VDJ on my system but not the stream.
Thanks.
Thanks.
geposted Thu 17 Nov 11 @ 8:56 pm
only thing i can think of is using a 3rd party software (IE winamp) and use an output source on your mixer connected to the Line in (mic) of another laptop or computer using an rca to 3.5 aux cable. that way if you lower the sound the sound of vdj you dont affect the sound of the stream as the sound will continue to come out of the output channel on your mixer that you use. I may be wrong but you can try it out see if that works.
Just an idea
Charlie C
Just an idea
Charlie C
geposted Fri 18 Nov 11 @ 2:55 pm
Thanks for the replay and That would probably get the job done quite effectively...I don't have the Equipment but I know where I kin borrow it, I will try it thanks.
geposted Sat 19 Nov 11 @ 8:30 pm
