Hey DJs,
I have a Numark DMC2 that I use as my primary controller.
Im looking to add another controller to control the effects in VDJ.
Any recommendation?
Thanks
Any recommendation?
Thanks
geposted Fri 18 Nov 11 @ 8:50 am
Is say a Korg NanoKontrol. Plenty of knobs, buttons and sliders.
Happy Hunting
Huey
Happy Hunting
Huey
geposted Fri 18 Nov 11 @ 9:35 am
You think theres a way to rack mount it?
geposted Fri 18 Nov 11 @ 9:37 am
in terms of having a controler just for effects, I'd say the novation nocturn is the best suited...
pro's
cons
this is the size relative to that guys hand
pro's
- 8 mapable endless encoders
- 1 endless encoder that will change anything you are pointing at with the mouse
- encoders have led position feedback
- encoders are touch sensitive so you could map it to turn on an effect when touched
- has a horizontal (crossfader) slider
- 8 mapable led feedback buttons
- 8 buttons for changing the midi values the controller sends
cons
- you need to run the novation automap software in the background
- no one has mapped it to vdj yet, so you will have to
geposted Fri 18 Nov 11 @ 10:26 am
