Hi.
I need 2 50ft xlr snakes (No breakout box)
This has been impossible to find so far. I "could" make them myself but I can't solder to save me life.
if I could purchase what I need, I would be pretty happy.
Any ideas?
Any ideas?
geposted Sat 19 Nov 11 @ 10:12 am
Are these for your speakers?
geposted Sat 19 Nov 11 @ 10:19 am
Yep....
What's happening is, i'm lazy. lol
I have my powered system. 2 powered subs, 2 powered tops. They sound good coming straight from the mixer but sound GREAT going from the mixer to the Driverack to the Sonic Maximizer.
I want to have 2 50ft leads that stay connected to the driverack that I can simply take out and run to the powered speakers. I already have leads for my inputs. If I have two 2ch XLR snakes, I can simply run each snake to each stack of speakers. Of course I could simply use 4 regular XLR's but they are kinda thick and bulky for my purposes.
The Furman I have is deep so I can not use a shallow rack. I have to use a standard amp rack. The driverack is shallow and is NOT easy to get to in the rack in the dark. That's why I want to have the XLR's stay plugged into the driverack. I don't want to use a XLR plate mostly because i'm lazy and don't want to constantly plug and unplug on both ends.
Snake XLR's are MUCH thinner and more flexible. I can keep the cables plugged into the driverack and simply run them out to the stacks.
geposted Sat 19 Nov 11 @ 10:44 am
What about this for an idea.
or this
https://virtualdj.com/homepage/mp3jrick/blogs/4588/Wireless_Audio_System.html
To be honest with you City I don't know what type of snake you want, do you mean 2 XLR leads in one so you only have one lead to run?
PS, The Sennheiser units only last for around 6 hours before the battery's run out :(
geposted Sat 19 Nov 11 @ 10:55 am
I bought my 50 foot cables from here. http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10244&cs_id=1024401&p_id=4756&seq=1&format=1#largeimage
geposted Sat 19 Nov 11 @ 10:58 am
City - you are going to be hard pressed to find a 50ft 2 channel 'snake' setup. You are better at just getting some 'short' cables that easily brings your connection points closer to you in your rack. I picked up some short cables a while back for this same reason.
But, I don't think you are going to find any 2 channel snakes out there.
geposted Sat 19 Nov 11 @ 1:03 pm
@George...
I have plenty of 10ft, 25ft, 50ft and 100ft xlr cables but they are all thick. What i need is a THIN cable.
Something like this but only 4ch.
http://www.ebay.com/itm/250582842399?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_2402wt_1112
Better yet, two of them but 2ch each.
geposted Sat 19 Nov 11 @ 2:25 pm
I think you are right. I guess i will just have to make them myself. I don't know where to find the actual cable though.
geposted Sat 19 Nov 11 @ 2:28 pm
I have these that I connect to my outs on my M-Audio mixer http://www.guitarcenter.com/Monster-Cable-DJ-Cable-Dual-XLR-Male-to-XLR-Female-102956463-i1128738.gc
.....And the Sennheisser that work perfectly for two years now, no doubt they do a great job....
I just wish I can find a wireless solution for VGA video monitors.?? Anyone can help with this...
Thanks
Thanks
geposted Sat 19 Nov 11 @ 2:45 pm
If I can find my original order I will post it here - I actually pick some very nice well made one up a couple years ago -- and I even got them in different colors :)
geposted Sat 19 Nov 11 @ 2:52 pm
You don't really need to,if you buy the right connectors. Nutrick, I believe, makes a solder-less XLR, male and female, connector. Do a google search for it.
geposted Sat 19 Nov 11 @ 3:00 pm
http://whirlwindusa.com
Fantastic quality cables, and I think they'll build you custom snakes.
geposted Sun 20 Nov 11 @ 4:51 pm
whirwind makes some fantastic cables. i have several of their swivle xlr cables.
I have found what i'm looking for...
http://www.ebay.com/itm/140548022794?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_1257wt_1112
http://www.ebay.com/itm/310334014593?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_1161wt_1346
this is exactly what i'm talking about. If this helps anyone else...GOOD. We all need to share the wealth.
geposted Sun 20 Nov 11 @ 6:53 pm
