Hi all!
since I installed the latest version of virtual dj, the loop do not work properly.
FYI, I use the Hercules DJ Control Steel skin modified by me as follows:
- No visualisation
- No BPM information
- button "2" is mapped to activate loop with 4 times. For this, I use the following function:
"loop loop_select & 4"
This function changed since the last version? Should we use another function?
I also noticed that the effects were not working as before also, they walk less (eg. The effect "beatgrid" does not realize its full jumps, suddenly it makes a strange sound and ugly ...)
I'm a little bummed because before it working like a charm....
Someone have the same problem as me or am I the only one?
thank you for your help!
Http: / / www.djaxman.fr
- No visualisation
geposted Sun 20 Nov 11 @ 11:21 am
How that loop statement was ever working in the past is beyond me ... the proper statement is --> loop 4
That is it - it sets a 4beat loop when pressed.
About the BeatGrid effect - something must have changed in your beat pattern selection.
Where you using the default pattern before?
geposted Sun 20 Nov 11 @ 12:40 pm
